Mcfk Carbon Road Handlebar
Article number: | 010-02-05 |
Germany-based MCFK has been making a name for themselves producing high quality handmade carbon components. Their first handlebar uses the 31.8mm diameter compatible with most modern stems. Many co-molded pieces of UD, 1k and 3k carbon fiber are a masterfully crafted into a comfortable ergonomic shape. The tops feature several degrees of backsweep for relief on the wrists. A channel on the underside routes the cables cleanly and maintains a comfortable round profile under the tape. The transition out to the hoods is very flat to allow a long perch with many comfortable positions. The drops are relatively shallow at 130mm with a long graceful curve that flares out a few degrees. These bars are very stiff with a 100kg weight limit. Please use a calibrated torque wrench and follow the manufacturer's guidelines for maximum torque settings.
Size | C to C Hoods | C to C Drops | Weight |
38 cm | 38 cm | 41 cm | ~151g |
40 cm | 40 cm | 43 cm | ~154g |
42 cm | 42 cm | 45 cm | ~156g |
40 cm | 44 cm | 47 cm | ~159g |
Reach | 77 mm | ||
Drop | 130 mm | ||
ICR Compatible | No | ||
Back Sweep | 5° | ||
Drop Angle | 4° | ||
Clamp Diameter | 31.8 mm | ||
Rider Weight Limit | 100kg |
