Mcfk Carbon Mountain Rims
$690.00
Known for producing some of the most handsome gram-conscious components on the market, Mcfk has been making a name for themselves by contributing to elite builds for years. With each part meticulously crafted by hand in Germany, all Mcfk components reflect an obvious attention to detail with a dedication to quality.
In an attempt to make the best possible rim for lightweight MTB builds, Mcfk spent countless hours researching and developing the most ideal method for producing carbon rims, and yielded truly impressive results. By focusing on the layup of each individual layer of carbon in their rims, Mcfk was able to produce the absolute finest ride characteristics, coupled with an impressive amount of strength. Unlike many other carbon rim manufacturers, Mcfk builds each rim using a monocoque system, thus guaranteeing excellent strength. Each rim in crafted from a single laminated piece that is then curved into the ideal shape, thus producing a homogeneous rim with high stability and improved weight savings. Additionally, the geometry of each Mcfk carbon rim has been dialed in to produce nearly perfect wheelbuild characteristics. With an asymmetric profile, spoke tension is even throughout the build, yielding a well balanced, stronger wheel. As an added measure of ingenious design, spoke holes on the Mcfk carbon rims are compressed and laminated, achieving a much higher level of durability than carbon rims with crudely drilled holes. Proving to be one of the most well made rims on the market, the Mcfk carbon MTB rim is the ideal choice for the discerning cyclist in search of weight savings and durability rolled into one incredible package.
For their mountain rims, Mcfk recommends tire widths between 1.95 and 2.35 inches.
Assembly
We recommend that wheels with Mcfk carbon rims be assembled by an experienced wheel builder. Mcfk recommends a maximum spoke tension of 110 kgf, with an average of 100 kgf. Tubeless tape with a width of 25mm is recommended, paired with 46mm long tubeless valves.
Weights
27.5"360 grams
29"400 grams
External Width (front/rear)35mm
Internal Width (front/rear)24.5mm
Depth (front/rear)29 mm
ERD (27.5/29)542/580mm
Tire Compatibilityclincher, tubeless
Recommended Tire Width1.95-2.35" (50-60mm)
Materialcarbon fiber
FinishUD Matte
*Nipples, Rim Tape, and Tubeless Valves are NOT included
