Mcfk Carbon ICR Road Handlebar
$405.00
Article number: 010-01-01
The Mcfk Road Handlebar exemplifies precision German engineering and advanced carbon fiber craftsmanship, making it a top choice for performance-driven cyclists. Balancing lightweight agility, stiffness, and vibration damping, its multi-weave carbon construction ensures strength and responsiveness for both racing and endurance rides. Designed for 31.8mm stems, it features a rounded profile with an integrated cable channel and full ICR (Internal Cable Routing) compatibility for a clean setup with mechanical or electronic drivetrains.
Ergonomic refinements include a subtle backsweep for improved wrist comfort, 130 mm shallow drops for accessible hand positioning, and a 4-degree flare for enhanced control, especially on technical descents. Despite weighing as little as 147g, it supports riders up to 100kg (220 lbs.), demonstrating exceptional structural integrity. Available in 38cm, 40cm, 42cm, and 44cm widths, it suits various rider preferences and geometries.
For longevity and secure installation, always use a torque wrench per manufacturer specifications. With its cutting-edge materials, refined ergonomics, and race-ready design, the Mcfk Road Handlebar is the ultimate upgrade for discerning cyclists.
 Size 38 cm 40 cm 42 cm 44 cm
 C to C Hoods 38 cm 40 cm 42 cm 44 cm
 C to C Drops 41 cm 43 cm 45 cm 47 cm
 Weight ~151g ~154g ~156g ~159g
 Reach 77 mm
 Drop 130 mm
 ICR Compatible Yes
 Back Sweep
 Flare
 Clamp Diameter ø 31.8 mm
 Rider Weight Limit 100kg
