Mcfk Carbon Aero Handlebar
$515.00
Article number: 010-01-05
The beautifully hand-crafted in Germany MCFK Caron Aero Handlebars check all the boxes. Light, stiff, aero and comfortable, these bars feature a several degree angled back sweep on the tops and comfortable short and shallow slightly flared compact drops.
Featuring MCFK's signature carbon sheen, these aerodynamic handlebars not only cut through the air, but match MCFK's stem and seatpost options, completing a tricked out unique look for your ride.
 Size C to C Hoods C to C Drops Weight
 38 cm 38 cm 41 cm ~ 170 grams
 40 cm 40 cm 43 cm ~ 173 grams
 42 cm 42 cm 45 cm ~ 176 grams
 44 cm 44 cm 47 cm ~ 180 grams
 Reach 77 mm
 Drop 130 mm
 Rider Weight Limit 100kg
 Clamp Diameter 31.8 mm
 Drop Angle
 Top Angle
