$20.00
Article number: 011-03-03
KEO Cleat
The MADE by LOOK KEO standard is recognized in the cycling world for its minimal weight and compact design of the cleat and pedal combo. Of course compatible with all pedals on the market, their memory positioner is a major advantage when changing your cleats. Their principle and use are the same as the DELTA cleat standard; engagement and disengagement remain efficient and reassuring. Three float options available with corresponding colors.
Memory positioner
 Material Polyamide & PTFE
 Angular freedom 0°, 4,5° or 9° (black, grey or red)
 Use Road
 Lateral adjustment 4 mm
 Longitudinal adjustment 12 mm
 Weight pair+fastenings 68g
 Accessories Six screws(5x11mm) & 6 washers
