Look Kéo Classic 3 Plus Pedals
$85.00
Article number: 011-03-02
Keo Classic 3 Plus
  What is the difference between a KEO CLASSIC 3 and a KEO CLASSIC 3 PLUS? The material used for the contact area. The little extra, stainless steel rather than composite, optimizes pedal stiffness and hence the transfer of power from you to your bike. As for the rest, we stick to what works: fast clip in / clip out and easy tension adjustment.
 Technology Spring
 Body material Composite
 Platform material Stainless steel
 Platform area 400 mm²
 Platform width 60 mm
 Total stack height (pedal + cleat) 17,8 mm (11.5 + 6.3 mm)
 Q Factor 53 mm
