Look Kéo Classic 3 Plus Pedals
Article number: | 011-03-02 |
Keo Classic 3 Plus
What is the difference between a KEO CLASSIC 3 and a KEO CLASSIC 3 PLUS? The material used for the contact area. The little extra, stainless steel rather than composite, optimizes pedal stiffness and hence the transfer of power from you to your bike. As for the rest, we stick to what works: fast clip in / clip out and easy tension adjustment.
Technology | Spring |
Body material | Composite |
Platform material | Stainless steel |
Platform area | 400 mm² |
Platform width | 60 mm |
Total stack height (pedal + cleat) | 17,8 mm (11.5 + 6.3 mm) |
Q Factor | 53 mm |
