Look Kéo Blade Pedals
Article number: | 017-03-04 |
The Keo Blade Ceramic pedal is a high-performance system for ambitious cyclists. It combines lightness and durability with a rigid carbon body and ceramic bearings for smooth performance. Blade technology offers four adjustable tension settings for optimal power transfer. Its aerodynamic design and wide platform provide comfort by distributing pressure evenly. Weighing about 95 grams per pedal, it's engineered for countless kilometers of training and racing. With a 14.8mm stack height and 53mm Q-Factor, it ensures a stable, efficient rider-bike connection. Beyond its weight, its power-to-weight ratio is the best in class on the market today. Light, aerodynamic and powerful, the pedal has all you need to take it to the next level, all the way to victory.
Ceramic Ti | Carbon Ceramic | Carbon | |
Material (Body) | Carbon | Carbon | Carbon |
(Spindle) | Titanium | Chromoly+ | Chromoly+ |
(Blade) | Carbon | Carbon | Composite |
Blade Strength | 16 Installed | 12 Installed | 8 Installed |
12 Included | 8 Installed | 12 Installed | |
Bearings | Ceramic | Ceramic | Stainless Steel |
Platform | 67 mm | 67 mm | 67 mm |
Stack Height | 14.8 mm | 14.8 mm | 14.8 mm |
Q Factor | 53 mm | 53 mm | 53 mm |
Weight (Pedal Set) | ~190g | ~220g | ~230g |
Warranty | 3 years | 3 years | 3 years |
