This 2.5mm version is the middle weight of the three DSP tape options. This version is recommended for most riders, those who seek a perfect balance between comfort and control with the premium tacky feel that Lizard Skins is known for.
Includes two rolls of tape, bar plugs, clamp cover strips, and premium finishing strips.
Weight per Roll | 28 grams |
Weight per 100cm | 13.5 grams |
Weight, Bar Plugs (pair) | 12.3 grams |
Roll Length | 208 cm |
Thickness (measured) | 2.7 mm |
Material | polymer |
