Lizard Skins DSP 1.8 Bar Tape
$41.99
Article number: 004-01-03
This 1.8mm version is the thinnest and lightest of the three DSP tape options. This version is recommended for riders who prioritize grip and control over comfort, as well as those who want to minimize bike weight while retaining a modicum of comfort.
Includes two rolls of tape, color-matched bar plugs, clamp cover strips, and premium finishing strips.
Weight per Roll 27 grams
Weight per 100cm 13 grams
Weight, Bar Plugs (pair) 19 grams
Roll Length 208 cm
Thickness (measured) 1.8 mm
Material polymer
