Lilly Lube Chain Lube
$11.99
Article number: 017-02-03
Availability: In stock (3)
LillyLube is a complex blend of heavy-duty lubricants, purified solvents, and proprietary additives that reduce friction and make your chain run smooth.  LillyLube will penetrate and clean your chain, flushing out dirt and contamination.
LillyLube Features:
  • EP (extreme pressure) additives for superior film strength
  • Contains proprietary additives that reduce friction
  • Cleans everytime you use it
  • Petroleum-based lubricant
  • No added scents or dies
  • Made in the U.S.A
LillyLube Benefits:
  • Formulated by an engineer with a passion for cycling
  • Attracts a minimum amount of dirt and grit
  • Lower friction increases the speed
  • Performs equally as well in both wet and dry conditions
  • Increases chain life
  • Long lasting
  • Excellent for all type of bikes
  • Made in U.S.A
Bottle Size 4.23oz(125mL)
