Lilly Lube Chain Lube
Article number: | 017-02-03 |
LillyLube is a complex blend of heavy-duty lubricants, purified solvents, and proprietary additives that reduce friction and make your chain run smooth. LillyLube will penetrate and clean your chain, flushing out dirt and contamination.
LillyLube Features:
- EP (extreme pressure) additives for superior film strength
- Contains proprietary additives that reduce friction
- Cleans everytime you use it
- Petroleum-based lubricant
- No added scents or dies
- Made in the U.S.A
LillyLube Benefits:
- Formulated by an engineer with a passion for cycling
- Attracts a minimum amount of dirt and grit
- Lower friction increases the speed
- Performs equally as well in both wet and dry conditions
- Increases chain life
- Long lasting
- Excellent for all type of bikes
- Made in U.S.A
Bottle Size | 4.23oz(125mL) |
