Sale
Lightning Carbon Road Crankset V.1
$620.00 $525.00
$620.00
(You save $95.00 )
Closeout 15% off
The long awaited crank from Lightning has finally seen the light of day. Often copied, replicated and licensed, Lightning's revolutionary crank is now available with a number of bottom bracket options to adapt to most frame standards. The crank features carbon arms with an aluminum spider, joined in the center by a Hirst Joint (ala Campagnolo). Lightning claims a q-factor of 156 mm, however the pedal threads 2.5mm into the arm on either side, reducing the q-factor to a scant 144mm. Available in a number of lengths, as a standard 5-bolt 130BCD or compact 110BCD, a 4-bolt 110BCD (Shimano 9000/9100), Clydesdale, and with ceramic bearing upgrades. Additionally, compatible with Power2Max power meter.
Ordering
Lightning cranks are modular. Order the crank length, spider and bottom bracket that you need. We will install the spider arm onto the crank for you. If you're ordering a spare spider you'll need a spider tool. All Lightning Spiders are compatible with both Road and Mountain Lightning Cranks. If you desire a non traditional chainring setup, nearly any configuration can be achieved.  If the option is not available here, please contact us and we will be happy to order it for you.
Special Orders
If you'd like to order Clydesdale cranks or ceramic bottom brackets contact us.
Bottom Bracket CompatibilityBSA, BB30, PF30, BB86
Chainring Compatibility130BCD or 110BCD
Power Meter CompatibilityPower2Max
Crankarm Materialhollow carbon fiber
Spindle Material7075-T6 aluminum, hard anodized
Spindle Diameter30 mm
Center BoltM14, 6/4 titanium
Weight Limit, Standard220 lbs
Weight Limit, Clydesdale280 lbs
Weight
Crankarms~340 grams
Compact Spider37 grams
BSA BB82 grams
PF30 BB83 grams
BB86 BB40 grams
Product Manuals
Lightning Carbon Cranks Installation
Road Cranks
3K Gloss
3k Matte
Size:
165mm
Size:
170mm
Size:
172.5mm
Size:
175mm
Fits:
5-Bolt - 110 BCD
Fits:
4-Bolt - 110 BCD
Fits:
130 BCD
Style:
Road
Carbon
