Nothing can take the steam out of an awesome trail ride like an unexpected puncture. Often, the cause of a flat tire is an oversized puncture that sealant can't quite repair. In this situation a spare tube will get you riding again, but the increased tire pressure necessary for a tube and the increased chance of a second puncture or pinch flat make this a less-than-ideal trailside repair. Lezyne's ultra-compact tubeless tire repair kit has an answer for this frustrating situation: simply repair the tire puncture, inflate to your normal riding pressure, and enjoy the rest of your ride.
Lezyne's repair kit borrows a tried-and-true design from the automotive world, miniaturized for use on bicycle tires. A combination eyelet fork and reamer tool is used to prep the tire and install the rubber plug, sealing large punctures when sealant can't. The ingenious design houses the tool and five tire plugs in a small canister. When in use, the canister doubles as a convenient handle for the tool. The total weight of the system is a mere 47 grams, and is compact enough to fit in any saddle bag or riding pack.
See the link below for detailed usage instructions:
Lezyne Blog - How to Use the Tubeless Kits
Weight | 47 grams |
Included | Combination Tool & Canister 5 Tire Plugs |
