Leap Components Double Under-Bar Wireless Blip Mount
Article number: | 001-03-02 |
Delivering a clean, minimalist look, the Leap Double Under-bar Blip Mount holds two SRAM AXS wireless blips on the right side of your handlebar for better ergonomics and engagement. This innovative mount positions both blips next to your grip in the same location as the original SRAM AXS shifter, but with a larger surface area for improved shifting control. Precision CNC-machined from durable aluminum alloy, the sleek mount weighs ~22 grams and takes up minimal space between your grip and brake lever. Installation is easy with a secure fit on standard 22.2mm handlebars. With its lightweight yet robust construction, the Double Under-bar Blip Mount from Leap Components enhances the performance and aesthetics of your drivetrain.
SRAM AXS Blips are NOT included.
Mount | Buttons | |
Weight | ~8.5g | ~3.1 |
Button Option | Grip / Smooth / Small / No Button | |
Material | 3D Printed Carbon Filled Nylon (CF15) | |
Dimensions | 5 x 3 x 2.5 cm | |
Blips Weight | ~14g | |
Clamp | 22.2 mm |
