Leap Components Center-Bar Blip Mounts
$47.99
Article number: 001-03-02
Engineered for sleek style and intuitive ergonomics, the Center-bar Blip mounts elevate your SRAM wireless Blips AXS shifter setup. Two minimalist mounts secure a Blip button on either side of your 31.8mm handlebar stem, centering the controls for natural access without compromising your cockpit aesthetic. The wider interface grants confident engagement as you click through gears. 3D printed from durable carbon filled nylon, the svelte clamps weigh ~27 grams total (with blips), reducing load compared to stock Blips. Installation takes moments with the included 3mm hex key. Dial in the ideal position to complement your fit. With their low profile silhouette and textured grip buttons, the Center-bar Blip mounts streamline your contact points for good looks and intuitive function.
SRAM AXS Blips are NOT included.
  Mount Buttons
 Weight ~10.8g ~3.1
 Button Option Grip / Smooth / Small / No Button
 Material 3D Printed Carbon Filled Nylon (CF15)
 Dimensions 5 x 3 x 2.5 cm
 Blips Weight ~14g
 Clamp 31.8 mm
