KMC X11 11 Speed Chain
$35.00
Article number: 014-04-01
Availability: In stock (4)
With KMC's X11 chain an impressive combination of features conspire to create a chain that is tough and durable, with near-perfect shift performance. KMC's signature "Stretch Proof" treatment ensures the longest possible chain wear life, with super strong, fully riveted chain pins joining the links. Both inner and outer plates are specially shaped to aid shift performance. The plate edges are chamfered to allow quicker chain engagement across gears, and the outer plate surfaces are forged with KMC's Double X Bridge design, simultaneously aiding downshifting on the cassette cogs and upshifting on the chainrings. The outer plates are nickel plated, while the inner plates are left untreated for an attractive alternating black and silver chain.
All X-series chains are shipped with their Pro Chain Lube applied for optimal performance right out of the box. An 11-speed KMC MissingLink is included for convenient assembly and service. The X11 is compatible with all Campagnolo, Shimano, and Sram 11 speed drivetrains, and are suitable for both road and mountain applications. Current model chains have been upgraded for compatibility with 1x drivetrains.
Weight ~262 grams
Length 118 links
Dimensions 1/2” x 11/128”
