King Cage Stainless Steel Kargo Cage
$45.00 - $60.00
The Kargo Cage from Durango, Colorado-based King Cage presents an elegant alternative to the traditional saddle bag, or a great option for adding a little extra storage to your bicycle. This handmade cage is manufactured from durable stainless steel and includes a zippered ballistic nylon bag, with two different size options designed to accommodate either road or 29" mountain tubes (or whatever else you want to stow). The Road version will fit a single standard 700c tube, or two lightweight 700c tubes. The Mountain version will fit a single 29er tube, with extra room for levers and a CO2 cartridge and inflator. When inserted into the cage, the nylon bag can be snapped into a pair of security straps that connect to the cage mounts, ensuring that the bag will stay in place over even the roughest terrain. We offer the Kargo Cage as either a single cage, or as a matched pair with a standard King Cage Stainless Cage
Road Bag Dimensions7.5 x 3 x 1.25" (19.1 x 7.6 x 3.2cm)
Mountain Bag Dimensions9.5 x 3 x 1.25"(24.1 x 7.6 x 3.2cm)
Stainless Steel
