Kcnc Universal Tubeless Valves
$20.00
With their ever-evolving product line, KCNC has created some truly unique products. While the tubeless valve is nothing new, KCNC has added some small intricacies that place their valve a cut above the rest. Each valve starts with a 7075 aluminum precision-machined stem, anodized in the signature Kcnc hues. To the color matched valve caps and presta valve lockrings this valve possesses stunning looks from stem to stern. Standard to all proper tubeless valves, these come with removable cores making tire seating a breeze. The truly novel idea that Kcnc brings to the table is the sealing grommet used. For each valve, Kcnc supplies a set of five individually molded sealing grommets. These grommets are specifically designed to seal with the most common rim bed profiles on the market. Allowing these valves to be used with whichever tubeless system you are currently using, or will use in the future. Since these grommets are precision molded, they greatly increase success the first time around, keeping your sealant inside the tire and not all over the floor. They are often overlooked, but any product that makes setup and continued use a snap is always a good thing in our book.
Each package contains two valves in either 38, 50 or 65mm lengths, along with five pairs of rubber adapters to fit different shape rim beds.
Weight, 38mm~9.5 grams per pair
Weight, 50mm~11.0 grams per pair
Weight, 65mm~12.5 grams per pair
Material7075 Aluminum
Tubeless Valves
Blue
Gold
Green
Pink
Red
Style:
Mountain
Style:
Road
Aluminum
