KCNC Ti Pro Lite Seatpost
$160.00
$120.00
* Unit price: $120.00 /
Article number: 018-05-02
 This zero setback post features a lightweight, simple rail clamp design that allows for easy installation and adjustment. In designing this post, KCNC opted to use a variety of materials; the main tube is machined from high strength scandium aluminum, the clamp hardware from 7075 aluminum, and the clamp bolts are manufactured from 6/4 titanium. It should be noted that these titanium bolts are 6mm in diameter, where other manufacturers with similar seatpost designs use a more fragile 5mm bolt. This post strikes an impressive balance between durability, low weight, and affordability. Recently, KCNC has expanded options to include a variety of colors, diameters, and lengths. Additionally, the rider weight limit is quite generous for a seatpost in this weight class.
INSTALLATION
When installing this seatpost in a metal frame, we recommend applying grease to in the inside of the seattube to prevent corrosion and allow for easy installation. With composite frames, an assembly compound such as Park Tool Assembly Compound should be used. A 4mm hex wrench is required to adjust and tighten the rail clamp bolts, with a maximum torque rating of 5 Nm. The nature of the saddle rail clamp allows it to accommodate most standard round and oval saddle rail designs in steel, titanium, or aluminum.
  27.2 mm 30.9mm 31.6mm 34.9mm
350mm ~156g ~165g ~168g ~171g
400mm ~172g ~181g ~187g ~193g
Max Torque 5Nm 5Nm 5Nm 5Nm
