Kcnc Ti Pro LIte AL75 Seatpost
$62.00
KCNC is responsible for the creation of a plethora of performance tuned components at an affordable price. For years they have demonstrated their excellence it both design and craftsmanship in a variety of platforms and have proven themselves to be a company every serious cyclist should now.
With the introduction of the Ti Pro Lite AL75, KCNC hopes to meet the rigorous demands of the budget minded cyclist who requires a high level of performance from each of their components. Similar to the venerable Ti Pro Lite in shape, but significantly different in price and material. Crafted from 7075 T6 aluminum alloy as opposed to the traditional scandium found in the Ti Pro Lite, the Ti Pro Lite AL75 is both lightweight and extremely durable while keeping cost down. In a further effort to shave the price as much as possible, KCNC has equipped each Ti Pro Lite AL75 with stainless steel hardware, ensuring all tilt, fore, and after adjustments remain exactly where you desire, even over rough terrain. Offered with 0mm of setback, as well as 2 distinct lengths, the Ti Pro Lite AL75 is the ideal seatpost to perfectly dial in your fit, while keep weight down and reliability up. Rated for both MTB and road use, the Ti Pro Lite AL75 may be one of the most versatile seatposts we carry.
Post Material7075 T6 aluminum
Yoke Material7075 T6 aluminum
Bolt Materialstainless steel
Rider Weight Limit (XC)85 kg (187 lbs)
Rider Weight Limit (Road)100 kg (220 lbs)
Max Torque5Nm
Rail Compatibilityround
ovalized
Minimum Insertion
350mm65mm
400mm100mm
Weights
27.2mm, 350mm188 grams
27.2mm, 400mm207 grams
30.9mm, 350mm202 grams
30.9mm, 400mm218 grams
31.6mm, 350mm205 grams
31.6mm, 400mm227 grams
Straight Post
Size:
350mm
Size:
400mm
Diameter:
27.2mm
Diameter:
30.9mm
Diameter:
31.6mm
Aluminum
