SRAM derailleurs feature a rotating cable pulley wheel that acts as a radius for the section of rear shift cable between the derailleur cable stop and pinch bolt (completely different from the pulley wheels that guide the chain, which are available here). SRAM's factory cable pulley wheels are manufactured from plastic and are susceptible to damage and wear. In addition, the higher overall shift cable tension of modern 11 and 12 speed drivetrains can result in small parts such as these wearing mush faster; plastic parts that act as cable guides often develop grooves as a result of increased cable friction, a type of wear that can inhibit proper cable movement making proper derailleur adjustment impossible. KCNC, never short on ingenious solutions, has designed an aftermarket replacement option for SRAM's factory cable pulley wheels. Compatible with X01, XX1, X01 Eagle, and XX1 Eagle derailleurs, KCNC's SRAM Derailleur Pulley Wheel features many improvements over the original factory part. Instead of plastic, KCNC's cable pulley wheel is manufactured from lightweight 7075 aluminum, giving it increased durability while still weighing only 3.5 grams. Handsomely finished in anodized black (with white logos), this aftermarket solution not only adds a bit of "pop" to the rear derailleur relative to the plain finish of the original, but also provides a slicker, more friction-free surface for the cable to route over. Please feel free to contact us with any fitment questions.
Weight | 3.5 grams |
Compatibility | SRAM X01, XX1, X01 Eagle, and XX1 Eagle Derailleurs |
Material | Lightweight 7075 Aluminum |
