KCNC SE Pro Lite Ti Offset Seatpost
$120.00
Article number: 019-01-02
Designed and built with the same specs as the venerable Ti Pro Lite, the Sepro Lite Setback Seatpost from KCNC comes with 25mm of offset and is undoubtedly one of the finest setback posts available. Equipped with the same titanium hardware and 7075-T6 aluminum yoke system seen on the Ti Pro Lite, the Sepro Lite is a performance tuned seatpost ready for anything. Carefully machined from a scandium alloy tube, the Sepro Lite represents KCNC’s versatility in design and construction. With 25mm of offset, the Sepro Lite makes dialing in your ideal fit an effortless endeavour, while simultaneously maintaining a unique minimalist aesthetic. Budget friendly, light, and attractive, the Sepro Lite from KCNC is sure to find a home on a range of builds from budget minded to boutique.
  27.2 mm 31.6mm
350mm ~188g ~205g
400mm ~201g ~220g
Max Torque 5Nm 5Nm
