With a wide range of aftermarket, race ready components designed to outperform OEM parts, KCNC is a name every gram conscious rider should know. Whether you’re upgrading your current ride, or spec’ing out your next build, KCNC provides the components you need to give you the edge on race day.
Designed and built with the same specs as the venerable Ti Pro Lite, the Sepro Lite Setback Seatpost from KCNC comes with 25mm of offset and is undoubtedly one of the finest setback posts available. Equipped with the same race proven titanium hardware and 7075-T6 aluminum yoke system seen on the Ti Pro Lite, the Sepro Lite is a performance tuned seatpost ready to endure even the roughest terrain. Carefully machined from a scandium alloy tube, the Sepro Lite represents KCNC’s versatility in design and construction. With 25mm of offset, the Sepro Lite makes dialing in your ideal fit an effortless endeavour, while simultaneously maintaining a unique minimalist aesthetic. Skating the median between budget, weight, and looks, the Sepro Lite from KCNC is sure to find a home on a range of builds from budget minded to boutique.
Post Material | 7075 T6 aluminum |
Yoke Material | 7075 T6 aluminum |
Hardware Material | stainless steel |
Rider Weight Limit (XC) | 85 kg (187 lbs) |
Rider Weight Limit (Road) | 100 kg (220 lbs) |
Max Head Torque | 5 Nm |
Max Post Torque | 8 Nm |
Rail Compatibility | round ovalized |
Minimum Insertion | |
350 mm Length | 85 mm |
400 mm Length | 100 mm |
Weights | |
27.2mm, 350mm | 211 grams |
27.2mm, 400mm | 228 grams |
31.6mm, 350mm | 226 grams |
31.6mm, 400mm | 245 grams |
