Sale
Kcnc Scope Narrow-Wide Chainring
$70.00 $35.00
$70.00
(You save $35.00 )
Featuring the industry proven narrow wide tooth profile the new Scope chainring from Kcnc offers a durable option for riders looking to upgrade to a 1X drivetrain. With a full 5 mm thickness this chainring won’t flinch even under heavy torque. The reinforced construction provides extra rigidity for any situation you can throw at it. The robust design will shrug off rock hits and log strikes that would buckle competitors rings. Kcnc through their machining ingenuity have integrated threads into the chainring itself for further weight savings and added strength. Only the outer (male) portion of the chainring bolt is needed to install these rings. Crafted from 7075-T73 aluminum and anodized for durability this chainring will provide optimal performance under the harshest conditions. Finished off with an eye catching graphic the Scope chainring will pair perfectly with any crank. Offered in a range of tooth counts to dial in the perfect gear ratio this chainring is ideal for singlespeeds or any combination of 1X drivetrain. If you’re looking for a chainring that will keep you rolling no matter the conditions then the Scope chainring is the perfect fit for your bicycle.
We recommend using a quality torque wrench when installing any component. Especially one with aluminum threads. Installing this chainring only requires the male chainring bolt and the corresponding correctly sized wrench. Lightly grease the chainring bolts and install them hand tight before finalizing installation with your torque wrench. Periodically the chainring bolts should be checked to maintain proper torque and assure that they have not backed out.
Material7075-T73 Aluminum
Compatible Chainring Bolts Kcnc SL Double Chainring Bolts Parts of Passion Chainring Bolts Wolf Tooth 10mm Chainring Bolts
Weight
30T45 grams
32T61 grams
34T75 grams
36T88 grams
38T99 grams
Individual Chainrings
Size:
30T
Size:
32T
Size:
34T
Size:
36T
Size:
38T
Size:
Single
Aluminum
Fits:
104 BCD
Style:
Mountain Narrow-Wide
