Sale
Kcnc QR Rear Thru Axle
UPC:
Default Tax Class
$100.00 $60.00
KCNC's handsomely machined, and exceptionally light rear 12 x 142 mm thru axle skewer. CNC machined from 7075 aluminum and hard anodized for durability that can withstand the rigors of typical mountain bike abuse. The hollow axle uses the already popular and proven ball and socket joint to close the lever that all other KCNC skewers use, insuring an iron grip on your dropout. Add a dash of color to your build while simultaneously shaving precious grams.
Compatibility
These 12 x 142 mm quick release thru axles are designed to be compatible with the Syntace X12, Shimano E-Thru or RockShox Maxle standards. Please purchase accordingly.
Check out our blog for better info about which thru axle to use
ModelHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
DT Swiss (X12)TA 12 x 142Tapered160mm12 x 1.0 mm15mm49 grams
E-ThruTA 12 x 142Flat170mm12 x 1.5 mm15mm44 grams
Rock Shox/MaxleTA 12 x 142Flat172mm12 x 1.75 mm21mm47 grams
Material7075 Aluminum
Tool FittingQR/6mm Hex
Rear Thru Axle
Style:
Road Disc
Style:
Mountain
Interface:
Flat
Interface:
Tapered
Diameter:
TA 12 x 142
Fits:
12 x 1.0 mm
Fits:
12 x 1.5 mm
Fits:
12 x 1.75 mm
Blue
Green
Red
Aluminum
