KCNC Majestic Straight Seat Mast
Article number: | 020-03-03 |
The expert machinists at KCNC have designed an elegant looking seat mast cap that's sure to add some flair to your ride. CNC machined out of 7075 aluminum and equipped with titanium hardware, the Majestic seat mast cap is an excellent way to mount your saddle. With a variety of sizes, colors, and offsets, you're sure to find the right mast cap to dial in your ideal fit.
Ordering
The Majestic Seat Mast is available in two heights: 50mm and 100mm. The functional stack (the distance between the top of the frame's seat tube and the saddle rails) of these seatmasts are 20-40mm for the 50mm version and 30-90mm for the 100mm version.
Installation/Assembly
Be sure to use a torque wrench set to 5 Nm (max) for all mounting hardware on the Majesitc seat mast cap.
Diameter | 34.9 mm |
Lengths | 75 mm, 120 mm |
Offset | 0 mm |
Material | 7075 Aluminum |
Max Torque | 5 Nm |
Rail Compatibility | round ovalized |
Saddle Height Adjustability | |
75 mm, 0 offset | 2 cm |
120 mm, 0 offset | 7 cm |
Weights | |
75 mm, 0 offset | 88 grams |
120 mm, 0 offset | 109 grams |
