Kcnc Majestic 25mm Offset Seat Mast
$115.00 - $130.00
The expert machinists at KCNC have designed an elegant looking seat mast cap that's sure to add some flair to your ride. CNC machined out of 7075 aluminum and equipped with titanium hardware, the Majestic seat mast cap is an excellent way to mount your saddle. With a variety of sizes, colors, and offsets, you're sure to find the right mast cap to dial in your ideal fit.
Ordering
The Majestic Seat Mast is available in two heights: 50mm and 100mm. The functional stack (the distance between the top of the frame's seat tube and the saddle rails) of these seatmasts are 20-40mm for the 50mm version and 30-90mm for the 100mm version.
Installation/Assembly
Be sure to use a torque wrench set to 5 Nm (max) for all mounting hardware on the Majesitc seat mast cap.
Diameter34.9 mm
Lengths75 mm, 120 mm
Offset25 mm
Material7075 Aluminum
Max Torque5 Nm
Rail Compatibilityround
ovalized
Saddle Height Adjustability
75 mm, 25 mm offset1 cm
120 mm, 25 mm offset6 cm
Weights
75 mm, 25 mm offset101 grams
120 mm, 25 mm offset121 grams
Seat Mast
Gold
Red
Silver
Size:
75mm
Size:
120mm
Diameter:
34.9mm
Aluminum
