10% Off all 3T Components!
KCNC K-Series Cobweb Road Chainrings
Sign Up For Our Newsletter
You're Signed Up!
Weight, 110 BCD 34t30 grams
Weight, 110 BCD 50t82 grams
Weight, 110 BCD 39t33 grams
Weight, 110 BCD 53t94.7 grams
Weight, 130 BCD 39t33 grams
Weight, 130 BCD 52t83 grams
Weight, 130 BCD 53t80 grams
MaterialT73 7075 aluminum
UseRoad
KCNC K-Series Cobweb Road Chainrings K4, Black, 110 BCD, 34 Tooth $55.00 In Stock
KCNC K-Series Cobweb Road Chainrings Black, 110 BCD, 39 Tooth $55.00 In Stock
KCNC K-Series Cobweb Road Chainrings Black, 110 BCD, 50 Tooth $90.00 Notify Me When Available
KCNC K-Series Cobweb Road Chainrings Black, 110 BCD, 53 Tooth $90.00  1 Remaining
KCNC K-Series Cobweb Road Chainrings Black, 130 BCD, 39 Tooth $55.00  1 Remaining
KCNC K-Series Cobweb Road Chainrings Black, 130 BCD, 44 Tooth $90.00 In Stock
KCNC K-Series Cobweb Road Chainrings Black, 130 BCD, 52 Tooth $90.00 In Stock
KCNC K-Series Cobweb Road Chainrings Black, 130 BCD, 53 Tooth $90.00  2 Remaining
KCNC K-Series Cobweb Road Chainrings Red, 110 BCD, 34 Tooth $55.00 In Stock
KCNC K-Series Cobweb Road Chainrings Red, 110 BCD, 39 Tooth $55.00 In Stock
KCNC K-Series Cobweb Road Chainrings Red, 110 BCD, 50 Tooth $90.00 In Stock
KCNC K-Series Cobweb Road Chainrings K4, Red, 130 BCD, 39 Tooth $55.00 In Stock
KCNC K-Series Cobweb Road Chainrings Red, 130 BCD, 52 Tooth $90.00 In Stock
KCNC K-Series Cobweb Road Chainrings Red, 130 BCD, 53 Tooth $90.00 In Stock
K-Series Cobweb chainrings from KCNC offer a lightweight, visually striking, and functionally sound aftermarket drivetrain option. The design-patented K-Series is aggressively machined from a flat sheet of aluminum for maximum weight savings, leaving behind an intricate crisscrossed structure that ensures maximum rigidity from the least possible amount of material. Included in this design are profiled teeth and eight sets of shift ramps and steel pins to provide excellent shifting performance.
K3 Series
The lighter of the two options in the K-Series chainrings, featuring slightly less material due to maximum machining. Perfect for those looking to shave critical grams off of their race bike in an effort to conserve valuable watts.
K4 Series
A few grams heavier than the K3 chainring in an effort to minimize flex during shifting. The result being ideal shift characteristics when they matter most. An excellent choice for those looking for an aftermarket drivetrain option that will shave weight while sacrificing little to no performance.
KCNC K-Series chainrings are available in standard 130 BCD and compact 110 BCD, with compact conversion 39 and 53 tooth chainrings for converting a compact crankset to standard road configuration.
