Kcnc Indexing Rear Thru Axle
UPC:
Default Tax Class
$30.00
Known for their extensive repertoire of aftermarket components designed to aesthetically accent, and mechanically perfect any level of build, KCNC is a name real world cyclists trust.
With the introduction of their 12 x 142 thru axle skewers, KCNC looks to set themselves apart with a unique style and mechanical advantage over other aftermarket skewers. Equipped with an easy to use system for dialing in the perfect skewer angle for your particular frame, simply press the red button in the center of the skewer handle and rotate the cam into any desired position in seconds. Additionally, each KCNC 12 x 142 thru axle skewer utilizes a free-floating knurled endcap, coupled with a brass washer in order to minimize friction between the skewer and frame, ensuring a proper fit every time. Available in a plethora of vibrant colors, ideal for tuning the aesthetic of your current ride or next build, the 12 x 142 thru axle skewers from KCNC are a simple way of adding a dash of flair.
Check out our blog for better info about which thru axle to use
ModelHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
E-thruTA 12 x 142Flat171mm12 x 1.5 mm18mm66g
E-thru BoostTA 12 x 148Flat177mm12 x 1.5 mm15mm67g
MaxleTA 12 x 142Flat17312 x 1.75 mm21mm64g
Maxle BoostTA 12 x 148Flat18012 x 1.75 mm18mm66g
Syntace X-12TA 12 x 142Tapered167mm12 x 1.0 mm19mm65g
Material6061 aluminum
Rod Material7075 T6 aluminum
Recommended Torque15Nm
Rear Thru Axle
Boost Rear Thru Axle
Style:
Mountain
Interface:
Flat
Interface:
Tapered
Diameter:
TA 12 x 142
Diameter:
TA 12 x 148 Boost
Fits:
12 x 1.0 mm
Fits:
12 x 1.5 mm
Fits:
12 x 1.75 mm
Blue
Gold
Green
Red
Silver
Aluminum
