Kcnc Indexing Front Thru Axle
UPC:
Default Tax Class
$30.00
Recognised as one of the leading manufacturers of race ready aftermarket components, KCNC has made a name for themselves with a variety of lightweight parts fit for even the most elite builds.
With the expanding popularity of the 15 x 100mm thru axle platform, KCNC has created a skewer option that sets itself apart in aesthetics, design, and price. Skillfully crafted with a totally unique cam, the Indexing 15 x 100mm thru axle skewer from KCNC is perhaps the finest aftermarket option available. Equipped with a clean, one-handed method for dialing in the perfect skewer angle for any frame, simply press the red button in the center of the skewer and rotate the cam to the desired position. By additionally utilizing a special rotating end cap, paired with a self lubricating brass washer, KCNC is able to greatly reduce friction during thru axle installation, resulting in an increase in torque, and overall extended wear life. Available in a slew of vibrant colors to perfectly color tune your build, the KCNC Indexing 15 x 100mm thru axle skewer is the perfect option for those seeking performance, aesthetics, and durability all in a budget minded package.
Check out our blog for better info about which thru axle to use
ModelHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
FoxTA 15 x 100Flat146mm14x1.517mm84 grams
Rock ShoxTA 15 x 100Flat148mm15x1.511mm86 grams
Material6061 aluminum
Front Thru Axle
Style:
Road Disc
Style:
Mountain
Interface:
Flat
Diameter:
TA 15 x 100
Fits:
14 x 1.5 mm
Fits:
15 x 1.5 mm
Blue
Gold
Green
Red
Aluminum
