Shimano’s I-Spec II mounting system allows for seamless integration of their shifters with the brake lever clamp. But if you want to brakes from another manufacturer this can cause a headache. Thankfully Kcnc has created a shifter clamp that allows the separation of the brake and shifter clamps. Sculpted with cnc machined lines and anodised in the rich Kcnc hues these clamps add a little flash to your ride without compromising functionality.
Please note that these shifter clamps are compatible with Shimano XTR M9000 and XT M8000 shifters featuring Shimano’s newest I-Spec II mounting system.
Sold in pairs.
Sold in pairs | |
Weight | 13 grams |
Compatibility* | XTR M9000 and XT M8000 |
Clamp Material | 7075 aluminum |
Bolt Material | Stainless |
* I-Spec II is not compatible with the older Shimano I-Spec A or B standard. |
