Kcnc Fly Ride 26.0 Road Stem
$45.00
KCNC is known for creating a plethora of components that are both lightweight, and budget oriented. The no frills Fly Ride stem is an excellent example of a performance minded, utilitarian stem fit for a wide range of uses. Crafted from forged 6061 aluminum for added strength and rigidity, the Fly Ride is the perfect stem for budget minded cyclists looking for a respectable amount of performance from their cockpit.
Weight124 grams
Material6061 aluminum
Hardwarestainless steel
Angle+/-5 degrees
Clamp Diameter26.0 mm
Stack38 mm
Max Torque5 Nm
Stems
Size:
70mm
Size:
80mm
Size:
90mm
Size:
100mm
Size:
110mm
Size:
120mm
Style:
Road
Diameter:
26.0mm
Aluminum
