KCNC EVA Foam Lock-On Grips
Meet the EVA Lock-On Grip by KCNC. Similar in shape to their original EVA foam grip, KCNC has improved the overall design by adding a nylon insert with a CNC machined aluminum lock-ring attached to ensure a secure interface between handlebar and grip. The EVA Lock-On grip can be adjusted easily using a standard 2.5 mm allen wrench, making it easy to change your position on the fly, while simultaneously ensuring a secure fit.
The KCNC EVA Lock-On Foam Grips are installed using a 2.5 mm allen wrench with a max torque rating of 2 Nm.
Material, Grip | EVA Foam |
Material, Lock-Ring | Aluminum |
Weight, Pair | 48.2g |
