- Home
- Drivetrain & Brakes
- Kcnc CB9 Road Brakes
Categories
With a collection of upgrades spanning across nearly every component of your build, KCNC makes a name for themselves by offering affordable and reliable options for the gram conscious cyclist.
Specially designed to accommodate up to 28mm wide rim profiles while simultaneously allowing for muddy, unfavorable conditions, the CB9 is KCNC’s economical offering suited for every build level. Crafted to withstand the abuse of the nastiest weather and conditions, KCNC has coupled the CB9’s masterfully machined 6061 aluminum caliper body with standard equipped stainless steel hardware to ensure component longevity. Additionally featuring a dual-pivot linkage system, the CB9 is the ideal budget-minded brake for those looking to find the median between performance and weight savings. Offered in a variety of colors, KCNC makes color tuning your next build a quick and painless process.
Weight | 210 grams |
Caliper Material | 6061 aluminum |
Hardware | stainless steel |
Equipped Pads | Swiss Stop BXP alloy pads |
Recommended Max Rim Width | 28mm |
