Kcnc CB10 Road Brakes
SKU:
7890
$300.00
Known for their impressive repertoire of affordable components designed for every level of build, KCNC has carved a name for themselves in the cycling community as one of the go-to choices for assorted upgrades.
Designed to fit rims up to 28mm wide while simultaneously providing ample room for mud and debris, the CB10 from KCNC is a brakeset that has the highest level of performance in mind. Equipped with all titanium hardware, the CB10 features an expertly machined 7075 aluminum dual-pivot linkage actuated design that gives plenty of stopping power, while keeping weight as low as possible. As a result of the use of 7075 aluminum, coupled with titanium hardware and machined brake pad holders, the CB10 is about 9% lighter than the KCNC CB9. Perfect for the discerning cyclist who requires exceptional performance with little-to-no weight penalty, the CB10 is sure to impress.
Weight192 grams
Caliper Material7075 aluminum
Hardwaretitanium
Equipped PadsSwiss Stop Black Prince for carbon
Max Recommended Rim Width28mm
Rim Brake - Road
Style:
Road
Red
Aluminum
