KCNC 7075 Rear Thru Axle
Article number: | 021-04-03 |
Precision machined from 7075 aluminum and vibrantly anodized, KCNC’s Low Profile 12x142mm Thru Axle is an exceptionally light upgrade option. Significantly lighter than OEM and rival companies equivalent options, these axles feature a low profile head that virtually eliminates the hang-ups on rocks and shrubs. For a sleek profile and lightest possible build these thru axles are the perfect choice. Available in KCNC’s signature colors to match any build theses axles offer a simple, functional, and beautiful option for those looking to upgrade.
Compatibility
KCNC’s thru axles come in several different threading and length options. Please make sure to select the correct axle type to go with your frame. For tool free installation check out KCNC’s Indexing and Quick Release thru axle options.
For complete sizing details on all of our thru axles please look HERE or give us a call.
E-Thru | Interface | Length | Thread | Pitch | Weight |
161 mm | Flat | 161 mm | 18 mm | 12 x 1.5 mm | ~27g |
171 mm | Flat | 171 mm | 18 mm | 12 x 1.5 mm | ~28g |
Boost 167 mm* | Flat | 167 mm | 18 mm | 12 x 1.5 mm | ~29g |
Boost 177 mm* | Flat | 177 mm | 18 mm | 12 x 1.5 mm | ~28g |
Maxle | |||||
173 mm | Flat | 173 mm | 21 mm | 12 x 1.75 mm | ~29g |
180 mm* | Flat | 180 mm | 21 mm | 12 x 1.75 mm | ~29g |
Syntace X-12 | |||||
163 mm | Tapered | 163 mm | 18 mm | 12 x 1.0 mm | ~28g |
Recommended Torque | 10Nm | ||||
Material | 7075 T6 Aluminum | ||||
Tool Fitting | 6 mm Hex | ||||
Hub Compatibility | T/A 12 x 142 | T/A 12 x 148* |
