Kcnc 7075 Low Profile Rear Thru Axle
$40.00
Precision machined from 7075 aluminum and vibrantly anodized, KCNC’s Low Profile 12x142mm Thru Axle is an exceptionally light upgrade option. Significantly lighter than OEM and rival companies equivalent options, these axles feature a low profile head that virtually eliminates the hangups on rocks and shrubs. For a sleek profile and lightest possible build these thru axles are the perfect choice. Available in KCNC’s signature colors to match any build theses axles offer a simple, functional, and beautiful option for those looking to upgrade.
Compatibility
KCNC’s thru axles come in several different threading and length options. Please make sure to select the correct axle type to go with your frame. For tool free installation check out KCNC’s Indexing and Quick Release thru axle options.
Check out our blog for better info about which thru axle to use
E-ThruHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
161 mmTA 12 x 142Flat161mm12 x 1.5 mm18mm27 grams
171 mmTA 12 x 142Flat171mm12 x 1.5 mm18mm28 grams
Boost 167 mmTA 12 x 148Flat167mm12 x 1.5 mm18mm28 grams
Boost 177 mmTA 12 x 148Flat177mm12 x 1.5 mm18mm28 grams
Maxle / X-12Hub CompatibilityInterfaceLengthThread PitchThread LengthWeight
MaxleTA 12 x 142Flat173mm12 x 1.75 mm21mm29 grams
Maxle Boost 180 mmTA 12 x 148Flat180mm12 x 1.75 mm21mm29 grams
Syntace X-12TA 12 x 142Tapered163mm12 x 1.0 mm18mm28 grams
Material7075 Aluminum
Tool Fitting5mm Hex
Rear Thru Axle
Style:
Mountain
Style:
Road Disc
Interface:
Flat
Interface:
Tapered
Diameter:
TA 12 x 142
Fits:
12 x 1.0 mm
Fits:
12 x 1.5 mm
Fits:
12 x 1.75 mm
Blue
Gold
Green
Red
Aluminum
