KCNC 7075 Front Thru Axle
$40.00
* Unit price: $40.00 /
Article number: 023-04-02
Availability: In stock (1)
Experience the minimalist allure of KCNC's Low Profile Thru Axles, a sleek alternative to their Indexing and Quick Release counterparts. Shedding grams without compromising strength, these 7075 aluminum axles, with a durable hard anodized finish, guarantee lightweight resilience on rugged rides. Designed for weight-conscious riders, these axles offer a touch of flair with KCNC's signature hues, ensuring an upgrade that merges style and substance. Lighter than OEM axles, they promise durability and a rock-proof design, embodying KCNC's commitment to high-performance, lightweight components for avid cyclists.
Compatibility
KCNC thru axles come in several different options. Please make sure to select the correct axle type to go with your frame. For tool free installation check out KCNC’s Indexing or KCNC's Quick Release thru axle options.
For complete sizing details on all of our thru axles please look HERE or give us a call.
Model Head Length Thread Pitch Weight
Fox / E-Thru Flat 146 mm 16 mm 14 x 1.5 mm ~32g
RockShox Boost Flat 148 mm 11 mm 15 x 1.5 mm ~32g
Fox Boost Flat 156 mm 16 mm 14 x 1.5 mm ~34g
Rock Shox Boost Flat 158 mm 11 mm 15 x 1.5 mm ~34g
Recommended Torque 10Nm
_____________________: _____________________
Material: • 7075 Aluminum
Hub Compatibility: • T/A 15 x 100 mm - T/A 15 x 110 mm
Tool Fitting: • 6 mm Allen
