Kcnc 6061 Rear Thru Axle
$25.00
KCNC's series of precision-machined 6061 aluminum thru axles present an excellent low-cost replacement option for frame manufacturer's stock thru axles. Compared to KCNC's 7075 Low Profile Thru Axles, these are about twice the weight, but half the price. As such, the 6061 thru axles are an excellent option for replacing lost or damaged thru axles, or as an upgrade to a lever-free design. Installation and removal are accomplished with a 6mm hex wrench, with tool fittings on either end of the thru axle for maximum convenience.
Compatibility
KCNC 6061 thru axles are available to fit 12 x 148 Boost frames, in either RockShox Maxle or Shimano E-Thru standards.
Check out our blog for better info about which thru axle to use
E-ThruHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
167 mmTA 12 x 148 BoostFlat167mm12 x 1.5 mm19 mm44 grams
172 mmTA 12 x 148 BoostFlat172mm12 x 1.5 mm19 mm44 grams
177 mmTA 12 x 148 BoostFlat177mm12 x 1.5 mm19 mm44 grams
MaxleHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
180 mmTA 12 x 148 BoostFlat180mm12 x 1.75 mm22 mm47 grams
188 mmTA 12 x 148 BoostFlat188mm12 x 1.75 mm22 mm47 grams
Material6061 aluminum
Tool Fitting6mm hex
Recommended Torque10 Nm
Rear Thru Axle
Boost Rear Thru Axle
Style:
Mountain
Style:
Boost
Interface:
Flat
Diameter:
TA 12 x 148 Boost
Fits:
12 x 1.5 mm
Fits:
12 x 1.75 mm
Blue
Gold
Green
Red
Aluminum
