Kcnc 6061 Front Thru Axle
$25.00
KCNC's series of precision-machined 6061 aluminum thru axles present an excellent low-cost replacement option for fork manufacturer's stock thru axles. Compared to KCNC's 7075 Low Profile Thru Axles, these are about twice the weight, but half the price. As such, the 6061 thru axles are an excellent option for replacing lost or damaged thru axles, or as an upgrade to a lever-free design. Installation and removal are accomplished with a 6mm hex wrench, with tool fittings on either end of the thru axle for maximum convenience.
Compatibility
KCNC 6061 thru axles are available to fit Fox and Rock Shox standard 15x100 and Boost 15x110 thru axle forks.
Check out our blog for better info about which thru axle to use
ModelHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
FoxTA 15 x 100Flat146mm14 x 1.5 mm16mm66 grams
Fox BoostTA 15 x 110 BoostFlat156mm14 x 1.5 mm17mm69 grams
RockShoxTA 15 x 100Flat148mm15 x 1.5 mm13.5 mm66 grams
RockShox BoostTA 15 x 110 BoostFlat158mm15 x 1.5 mm11mm70 grams
Material6061 aluminum
Tool Fitting6mm Hex
Front Thru Axle
Boost Front Thru Axle
Style:
Mountain
Style:
Boost
Interface:
Flat
Diameter:
TA 15 x 100
Diameter:
TA 15 x 110 Boost
Fits:
15 x 1.5 mm
Fits:
14 x 1.5 mm
Blue
Gold
Green
Red
