KCNC 6061 Front Thru Axle
Article number: | 021-03-02 |
KCNC's precision-machined 6061 aluminum thru axles—an ideal, budget-friendly alternative to stock options. Though twice the weight of the 7075 series, these axles offer a cost-effective solution without compromising quality. Perfect for replacements or lever-free upgrades, their 6mm hex wrench compatibility ensures easy installation and removal. KCNC prioritizes precision at an accessible price, empowering riders with reliable components for a seamless and enjoyable ride.
KCNC thru axles come in several different options. Please make sure to select the correct axle type to go with your frame. For tool free installation check out KCNC’s Indexing or KCNC's Quick Release thru axle options.
For complete sizing details on all of our thru axles please look HERE or give us a call.
Model | Interface | Length | Pitch | Thread | Weight |
Fox | Flat | 146 mm | 14 x 1.5 mm | 16 mm | ~66g |
Rock Shox | Flat | 148 mm | 15 x 1.5 mm | 13.5 mm | ~66g |
Fox Boost | Flat | 156 mm | 14 x 1.5 mm | 17 mm | ~69g |
Rock Shox Boost | Flat | 158 mm | 15 x 1.5 mm | 11 mm | ~70g |
Material | 6061 Aluminum | ||||
Tool Fitting | 6 mm Hex | ||||
Hub Compatibility | T/A 15 x 100 | T/A 15 x 110 mm | ||||
Recommended Torque | 10Nm |
