ISM PL Saddle
Article number: | FitWorks |
The PL, Performance Long, style saddles are a fresh take on the original ISM "Breakaway" and "Prologue" saddles. Sporting a 275mm long base, same as the PN 1.0/1.1, to allow for superb fore-aft rider movement. The rear measures 135mm wide - adding support for those that like to roll their hips back while climbing.
Like all ISM saddles, the PL saddles are nose-less and designed to remove pressure from soft tissue, ensuring maximum blood flow, no genital numbness and a healthier, more enjoyable ride.
Model |
Length |
Width |
Rails |
Padding |
Usage |
1.0 |
275 mm |
135 mm |
Stainless |
30-Series Foam & Gel |
Road, Mountain |
1.1 |
275 mm |
135 mm |
Chromoly |
40-Series Foam & Gel |
Gravel, Road, Mountain |
