Hsc PF30 Ceramic Adapter Bottom Bracket
$120.00
The Sram-developed PF30 bottom bracket shell standard was originally designed around the modern BB30 crankset standard. Fortunately, the enlarged shell with its narrow bearing stance allows this standard to be adapted to fit older 24 mm crankset spindles. HSC manufactures these PF30 compatible bottom brackets to fit both Shimano's Hollowtech II and Sram's GXP cranksets. These bottom brackets use the the same size 6805 bearings used in the manufacturers' stock bottom brackets, but offer a performance uprade with an ultra high quality hybrid ceramic configuration.
Feel free to contact us directly for technical questions.
Installation/Assembly
We recommend that PF30 bottom brackets be professionally installed. In the absence of a component-specific installation tool, a standard headset press may be used.
Cup Material aluminum
Weight, HTII 119 grams
Weight, GXP 123 grams
Bearing Size 6805w6 (2), Si3N4 ceramic hybrid
Shell Compatibility PF30, 68 mm
Road BB
Ceramic
Fits:
Shimano HTII
Fits:
Sram GXP
Size:
PF30
