HSC Ceramic Hybrid Bearings
$25.00
Article number: 016-06-02
HSC bearings are among the most affordable ceramic bearings on the market, with no compromise in quality. Most front and rear hubs can be completely retrofitted for under $150, while most outboard bearing bottom brackets can be upgraded for $70.
High Speed Cycling's ceramic hybrid bearings offer an affordable performance boost without compromising durability. Featuring grade 3 silicon nitride balls, these bearings provide superior roundness compared to top-quality steel balls. The ceramic balls are paired with precision-machined steel races and low-friction seals, resulting in reduced rotational mass, improved thermal stability, lower rolling resistance, and extended bearing life. HSC ceramic bearings maximize power transfer and fit most hubs and bottom brackets. Upgrade to professional-level technology with HSC bearings.
INSTALLATION
We recommend installation be performed by an experienced mechanic with a professional quality bearing press. Improper installation will negate the performance advantages of ceramic bearings, and significantly reduce their wear life.
Bearing I.D. O.D. Width
6000 10 mm 26 mm 8 mm
608 8 mm 22 mm 7 mm
609 9 mm 24 mm 7 mm
6801 12 mm 21 mm 5 mm
6802 15 mm 24 mm 5 mm
6803 17 mm 26 mm 5 mm
6804 20 mm 32 mm 7 mm
6805 - w6 25 mm 37 mm 6 mm
6805 - w7 25 mm 37 mm 7 mm
6806 30 mm 42 mm 7 mm
6900 10 mm 22 mm 6 mm
6901 12 mm 24 mm 6 mm
6902 15 mm 28 mm 7 mm
6903 17 mm 30 mm 7 mm
699 9 mm 20 mm 6 mm
