The HSC ceramic bottom bracket is an excellent choice if you're looking to upgrade your current stock BB. Utilizing hybrid ceramic bearings, the HSC bottom bracket results in less friction, and longer wear life than your typical stainless steel BB.
Manufactured to work with the Cervelo-designed BBRight system, the cups are CNC machined out of aluminum to ensure proper tolerances for an accurate press fit.
HSC's BBRight adapter bottom brackets are available for Shimano Hollowtech II, Sram GXP, and BB386 EVO cranksets*.
*The BB386 EVO version is compatible with long-spindle Sram BB30 cranksets.
Weight, Shimano | 99 grams |
Weight, Sram GXP | 112 grams |
Weight, BB386 EVO | 102 grams |
Bearings | GRD 3 hybrid ceramic |
Cup Material | Aluminum |
