HSC BB30 Ceramic Bottom Bracket
$120.00
Article number: 016-06-04
HSC's BB30 adapter bottom brackets enable the use of various cranksets in BB30 frames. Crafted from aluminum, they fit Shimano HollowTech II, SRAM GXP, DUB, and BB386 EVO cranks. The design enhances drivetrain stiffness and power transfer.
Incorporating hybrid ceramic bearings with silicon nitride balls, they offer reduced friction and increased durability with alloy steel races and dual-lip seals. Suitable for 68mm BB30 shells, these adapters are durable and efficient.
ORDERING
These adapters are designed to fit frames with 68mm wide BB30 bottom bracket shells. The option you require will depend on the crankset being used:
Shimano HTII - Adapts a BB30 frame to fit 24mm spindle cranks
SRAM GXP - Adapts a BB30 frame to fit stepped 24/22mm spindle cranks.
SRAM DUB - Adapts a BB30 frame to fit SRAM's proprietary DUB design, 29mm spindle crank.
BB386 EVO - Adapts a BB30 frame to fit 30mm spindle cranksets, sometimes referred to as "long spindle" BB30 cranksets.
BB30 - designed to fit BB30 30mm spindle cranksets.
Shell I.D. Shell Width
42 mm Road - 68 mm MTB - 73 / 83* / 84.5** / 120 mm***
 Crank  Shimano HTII SRAM GXP SRAM DUB BB386 / BB30
 Spindle 24 / 24 mm 24 / 22 mm 29 / 29 mm 30 / 30 mm
 Weight ~105g ~108g ~104g ~104g
 Bearings 6805 - w7 29 x 42 x 7 6806
 Material Aluminum - Si3N4 Ceramic Hybrid
 Installation Tool Quality bearing press
*Cannondale MTB / **Spec. MTB Alloy OSBB / ***Cannondale Fat Bike
INSTALLATION / ASSEMBLY
To avoid frame damage, we recommend that these BB30 bottom bracket adapters be professionally installed using a proper bearing press.
Please feel free to contact us directly for technical questions.
