HED Belgium R Disc Brake Rim
Article number: | 5085 |
HED Belgium R Disc Brake Rim, a top choice for riders seeking enhanced performance and versatility. Crafted with meticulous attention to detail, this alloy rim boasts a 25mm external width and 21mm internal width, optimizing tire volume for improved comfort, grip, and rolling efficiency across various terrains.
Designed with a 24mm rim depth, the Belgium R maintains a balance between aerodynamic benefits and responsive handling. Its tubeless-compatible feature allows for lower tire pressures, reducing the risk of flats and providing a smoother ride. The rim's welded joint ensures durability and a seamless finish, while the standard Presta valve drilling facilitates easy tire inflation.
Wheel Building
BELGIUM R DISC RIM | |
Weight | ~425g |
Material | Aluminum |
Hole Count | 28 / 32 |
External Rim Width | 25 mm |
Internal Rim Width | 21 mm |
Rim Depth | 24 mm |
Recommended Tire Width | 700 x 28 mm |
Tubeless Compatible | Yes |
ERD | 593 mm |
