Sale
Hed Belgium Plus Clincher Rim
UPC:
Default Tax Class
$165.00 $130.00
$165.00
(You save $35.00 )
As the designers of some of the finest alloy rims available, HED's Belgium is one of our top choices for custom wheel builds. As a result of extremely strict manufacturing tolerances and a high level of quality control, HED has produced a series of nearly perfectly round alloy rims that are rivaled by none. With such tight tolerances in place, this allows for finer wheel builds with better spoke tension balance, ensuring longevity. Additional features include a practically imperceptible welded seam and wider profile for maximum durability; each Plus rim is an investment in your bike’s future.
In the wake of rising popularity for wide profile road rims, HED has decided to produce perhaps one of the absolute finest options available. Slightly wider than the venerable C2 rim, the Plus is a 25mm wide road tubeless option that guarantees all the positive attributes desired from a wide profile. By widening the rim profile, air volume within the tire is increased, which results in better handling in corners and a more supple ride over rough terrain. If you constantly find yourself on a variety of terrain, be it dirt or paved, the Plus rim from HED assures an ideal ride for years to come.
Weight460 grams
Materialaluminum alloy
Outer Width25mm
Depth24mm
Tire Compatibility700c
Tubeless CompatibleYes
ERD592
Clincher Rims
Size:
700c
Fits:
20h
Fits:
24h
Fits:
28h
Fits:
32h
Style:
Road
Aluminum
