HED Belgium R Rim Brake Clincher Rim
$175.00
Article number: Rims
As the designers of some of the finest alloy rims available, HED's Belgium is one of our top choices for custom wheel builds. As a result of extremely strict manufacturing tolerances and a high level of quality control, HED has produced a series of nearly perfectly round alloy rims that are rivaled by none. With such tight tolerances in place, this allows for finer wheel builds with better spoke tension balance, ensuring longevity. Additional features include a practically imperceptible welded seam and wider profile for maximum durability; each Plus rim is an investment in your bike’s future.
In the wake of rising popularity for wide profile road rims, HED has decided to produce perhaps one of the absolute finest options available. Slightly wider than the venerable C2 rim, the Plus is a 25mm wide road tubeless option that guarantees all the positive attributes desired from a wide profile. By widening the rim profile, air volume within the tire is increased, which results in better handling in corners and a more supple ride over rough terrain. If you constantly find yourself on a variety of terrain, be it dirt or paved, the Plus rim from HED assures an ideal ride for years to come.
Wheel Building
HED BELGIUM R RIM BRAKE
 Weight ~460g
 Material Aluminum
 External Rim Width 25 mm
 Internal Rim Width 21 mm
 Rim Depth 24.5 mm
 Tire Compatibility 700 x 25
 Tubeless Compatible Yes
 ERD 593 mm
